  1. i was searching and didnt find any help yet . if i encode xvid with mainconcept mpeg encoder to svcd format i never get those 2 black above and under lines on tv. and the picture is terrible . tmpgenc is so f.... shit cuz it only chrashes down or it gives me illegal calculation......... but mainconcept is fast and very good. if i i encode mpeg 2 format with mainconcept i get 576*320 and nero wont recalculate the size like by 480*480. it has to be 480*480. if anyone knows what i have to do please help me. i need full screen (keep aspect ratio) option in mainconcept or how to burn 576*320 (cuz here picture is great)mpeg-2 mpg file.
    any help wanted thank you
    It is possible but kinda tricky:
    Set the MPEG-type to SVCD.
    Click on Details->Crop and scale.
    Deselect keep properties under Scale
    Set the Height to, 640 divided by (your source width divided by the height)
    Start encoding and check that it looks okey, it should be a bit squeezed because 480x480 should be resized to 4:3 resolution (640x480) but it should be some black borders.
    example:
    source video is 576x320
    set the height to 356 then, 640 / (576 / 320 ) = 355.555
  3. tnx for the advice i think it will work just gotta try on tv 8) 8) tnx a lot for your help
